Halo / projector fog lamps?
Old Feb 24, 2010 | 05:01 PM
  #31
Old Dogg™'s Avatar
Originally Posted by barrett_kenney
I Also the fog light hole is larger on the factory ford valance than on the aftermarket reproduction, thats why they don't fit as well if you changed the valance from the two wheel drive over to the four wheel drive style.
How do they project (look/work)?
Old Mar 1, 2010 | 09:04 AM
  #32
barrett_kenney's Avatar
They are as bright as my lowbeams with the H3 bulb that came with them and they have a sharp cut off line so they dont blind oncoming traffic if adjusted properly. Also my girl said the halos look realy cool at night.
Old Mar 1, 2010 | 09:17 AM
  #33
Originally Posted by mhburris
I ended up doing the same thing. A little trimming on the valance and it worked fine. What did you wire the halo to??
mhburris
I wired them to the running lights. I ran two wires from them down to the halos on each side, i used the female bullet connector as my halos came with the males. Each running light will have three wires on it, you want to use the black as a ground, and the brown is your hot wire.
Old Mar 9, 2010 | 12:23 PM
  #34
BXK109's Avatar
here are pics of my install, sorry about the quality, took them with my phone.
Both lights installed:
close up of trimming:
hope this helps some.
i want
Old Apr 2, 2010 | 01:58 PM
  #35
nonwoven29's Avatar
Those are BAD *** fog lenses I love the look and they should work just like the head lights. Too bad the auction ended with no relisting=( Did you get them on your truck and do you have a day and night pic with them on?
Originally Posted by campo141
I am going with these with an h.i.d kit
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Apr 5, 2010 | 09:26 AM
  #36
I purchased The bumper from a local parts supplier in Monroe La. I purchased the fog lights from racer-union.com. Installed them at the shop I work at in Monroe La. I will post some night pics as I put H.I.D. In them and have installed new matching headlamps. Later today when I get home I'll put them up.
