Saleen step pad problem on 04
I RECENTLY JUST FININISHED THE COMPLETE INSTALL OF THE SALEEN S331 BODY KIT ON MY (04 FX4 WHIPPLE 12 psi JDM TUNE)... I RAN INTO A BIG PROBLEM WITH THE MOUNTING OF THE SALEEN STEP PAD. whoops caps.. I have the saleen complete install disk and the rear end of the 04 and 05 are different. The 05 had 3 mounting bolts and bumper brackets on each side that the stock bumper attached too and the new Saleen, step pad was suppose to mount right up using the same 3 bolts and bracket.....Well not the case on an 04..mine has only 2 bolts and diff bumper brackets and I ended up losing my hitch receiver which (SUCKS)
As for the saleen step pad... I had to re drill new holes and find a way to make it fit.. Is there a part number for the up dated rear end brackets and bolts, just so I can use a hitch receiver again.....
Does any 1 have pics of the saleen edelbrock side exit exhaust, that's also being a pain
... can't see how it mounts up
As for the saleen step pad... I had to re drill new holes and find a way to make it fit.. Is there a part number for the up dated rear end brackets and bolts, just so I can use a hitch receiver again.....Does any 1 have pics of the saleen edelbrock side exit exhaust, that's also being a pain
