:confused: HEADLIGHT ?'S
Old May 17, 2009 | 06:59 PM
RebelOne's Avatar
Unhappy HEADLIGHT ?'s
I traded my stock chrome lights out with someone with black light. His truck sat higher than mine, so he aimed his headlights lower so the HID kits won't blind people. I tried to adjust them today since they're aimed a little too low for me, and it won't do anything. I need help with this.
Old May 18, 2009 | 08:31 AM
NoLongerJeepin's Avatar
Well first lets make sure you're doing it right, the screw on the back of the housing, turning clockwise will aim them down and vice versa.
Ok next...
When you are aiming them up and down, are the screws moving at all? Are the screws stripped out?
Report back and we'll figure out where to go from here
Old May 18, 2009 | 10:40 AM
TJ05FX4's Avatar
The adjustment screws are VERY small and point directly to the rear of the truck. I don't remember which way does what, but if you have the lights on and shining against the wall you can see them move when you rotate the adjustment screw. If you are turning it and nothing is happening, then it might be stripped as mentioned above.
The movements that a turn of the screw makes is very slight, so you need to pay close attention to it as you rotate it and watch the wall or whatever you are shining it up against to be sure its moving, even if just a little bit.
Old May 18, 2009 | 10:11 PM
RebelOne's Avatar
The screws turn, but when I do it, the beam doesn't move at all. I almost took the screw completely out and nothing, turned it the other way, almost all the way in, nothing. I hope there's an easy fix to this. I love these new headlights
