replacing 9140 fog light bulbs
Old Mar 29, 2009 | 02:05 PM
jakek88's Avatar
hello everyone. i was looking at replacing the 9140 fog light bulbs in my 08 f150. i found on ebay some LED bulbs that are 9005s, i was wondering if its a good idea to use these. Some people have reported their housings melting because of heat, but these are LEDs produce almost no heat. will these work?
http://cgi.ebay.com/ebaymotors/V-LED...Q5fAccessories
Old Mar 29, 2009 | 02:47 PM
NoLongerJeepin's Avatar
These bulbs are intended for use as a Day Time Running light or for aesthetic purposes only
It sounds like they won't put out enough light to be usable. What 9140's are you currently using? If you haven't already look into Silverstar bulbs, they're one of the best halogen bulbs you can buy.
Another option is HIDs. They run a lot cooler then halogens, and will put out quite a lot more light.
Old Mar 29, 2009 | 05:55 PM
mtylerb's Avatar
Exclamation
... but will glare uncontrollably into oncoming traffic.
Old Mar 29, 2009 | 08:53 PM
jakek88's Avatar
the 9140 bulbs are the stock lights the truck came with.
they are just for the fog lights. im trying to match the halo headlights im puting in my truck.
Old Mar 30, 2009 | 08:45 AM
Uncontrollably? No. You can aim the fog lights to prevent glare, or you could just turn them off.
Old Mar 30, 2009 | 03:16 PM
jakek88's Avatar
but these should work as just fog light bulbs though right?
Old Mar 30, 2009 | 07:49 PM
Yes they will work, you may need to trim one of the tabs on the bulb. I managed to finagle mine into the housing without any trimming. Go with the first ones that also have side firing LEDs, The second option wont reflect off the fog light housing.
Old Mar 30, 2009 | 08:24 PM
Beytill's Avatar
You could also check out PIAA 9005`s. they are even whiter the the SS, but the also cost more. PIAA`s also come with a 1 year warranty.
Old Mar 31, 2009 | 11:32 AM
jakek88's Avatar
ok. ill get those. thanks!
