DDM HID Relay Harness
I was wondering how many of you are running 35w HID light systems from DDM and if it seems to be ok, if you don't mind to add your year model I'd appriciate it.
Also, if you have the relay harness from DDM does it require you to cut your existing harness? I would like to build one with a heavier gauge wire but did not want to buy one for a reference.
Thanks guys
Thanks guys
not DDM, but heres mine from xenonlink. Hes a site sponsor so he will take care of you!!! Mine just plugged right in. took all of 30 minutes on both heads and fogs
good luck with DDm...I hear there customer service is wonderful
their harness is direct plug and play.
if you spend the extra $25 and get the Hi/Lo beams it comes with a wiring harness, which is worth $20 alone on there site. so its a win , win you get high beams and also a wiring harness for $25
something tells me I've had a long day...I did buy the high low kit...so I'm thinking that this big mess of wire laying beside me is probably a relay harness?
Did they use a relay thats as big as the ballasts?
Oh, and for all of the bad things said about DDM's customer service I mnust say that they were very easy to deal with as far as customer service...you should know before buying that it is possible your order will be set to backorder and you won't know that until you log into the site and look at the status. So if you need your HID's in a hurry...you don't want them from here. Otherwise they are nice people and everyone I spoke to spoke clear english.
