can this be done(HID related)
Old Mar 2, 2009 | 02:52 AM
Stephen87's Avatar
I want to buy thesehttp://www.jegs.com/i/Anzo/018/111031/10002/-1 but from what I understand they are just plug and play stock replacments my question is that if you can make the work with hids on bot high and low beam
Old Mar 2, 2009 | 03:25 AM
ELVATO's Avatar
As long as they fit in there, and they are the correct bulb type, they should work.
On the other hand, I don't know if putting HID high beams would be a good idea. I tried that, and ended up putting the bulbs in the fogs. At least in the Expy stock housings, there wasn't much difference, since I guess the light just goes everywhere. Also, you won't be able to flash, both because of warm up time, and because it isn't good for the HIDs to turn them on and off.
Old Mar 2, 2009 | 12:19 PM
Stephen87's Avatar
did not think about that one
I'll probably just buy them for the low and the fog lights then do that mod thing that lets you have your high low and fog lights on at the same time
Old Mar 2, 2009 | 04:15 PM
03Screwon22's's Avatar
yeah you can put HID on those, I did my with the low beam, no point buying for high beams really don't use it anyways... i had the one peice projector and and it use an h3 bulb, works great, then I change my mind and bought a black lightning headlights instead...
