Projection headlights install...
MimoUSA makes the projection headlights that I bought and I spent about 1-2 hours with install and I only got the left one in. The wiring was not the hard part I did that in 5-10 minutes. It was fitting the lights in, and now it looks like the blinker harness on the right side is getting in the way of installing it. when I go to but the blinker light in the headlight assembly the harness faces towards the middle of the truck when it is suppose to face outwards. has any one elses run into these problems? I ended up taking off the whole grill assembly just to make it easier.
So it ended up i need to leave the grill on. once i figured out how to do it with them off it was a breeze to do it with it on. They are a one piece and they only suck to put on because there are no instructions. But I feel it was worth it. the light put out is a little dimmer than I thought though. They would look sick on ur truck. Ill post photos soon.
