HID install question
Old Jun 7, 2008 | 06:46 PM
th3godf4th3r's Avatar
ok so i just got my HID's from HID4U and have some question
1) on the relay there is three wires connected to it, only about a foot long or so and they are colored blue,black and white
Where do these need to connect to?
Old Jun 7, 2008 | 07:24 PM
shaunakadub's Avatar
If I'm thinking of the same wires you are those would be the wires that go into the factory harness near the passenger side light (because the relay needs to be near the battery).
Black goes in the middle, than try out the other 2 in each location (one is high beam, the other is low) until you get the right ones in the right spot.
Old Jun 9, 2008 | 01:12 PM
so i had accidently cut the ground wire in half, the part that goes from the bulb to the relay
so i just soldered the two ground wires back together and plugged it in and still there is nothing.
what do you guys think it could be???
no blown fuses
