Who's bought a LED 3rd Brk from F150 Store?
I bought a plug and play 3rd brake light from the f150store and come to find out it's not plug and play. Does your 04-08 have three plugs? One for the brake and two for ext. cab lights. This light has only one plug for all and it's obviously a different type. I e-mailed and called and never heard back from them. Has anyone else ran into this?
http://www.f150store.com/Shop/ViewPr...eIndexID=64522
you have to follow the three plugs into the cab...inside is a single plug...thats where the 3rd brake light plugs in...after you remove the stock light on the right side youll see the back of 2 white push pin things...i took a chisel and cut the heads off b/c they hold the harness that you need in place...some ppl said they pulled the three wires and it came out and then you have to drop the headliner...just do what i did and itll take 5 min...
