In channel window vents
Has anybody experianced wind noise with the in channel window vents?
I might add I have only had them installed for one day. Does it take longer than that to form in place.
Once your vents are installed your windows should be left shut for at least 24hrs if I remember correctly to properly seat. I have set of weathertech in-channel vents on mine and with windows shut I have to wind noise, if you crack the window open a little you will have a little more wind noise than if you didnt have them on but nothing annoying-you will get used to it.
