Vision X lighting, Halogen, Offroad HID and LED
Old Feb 20, 2008 | 08:02 PM
ModBargains's Avatar
Cool Vision X lighting, Halogen, Offroad HID and LED
We at ModBargains.com are proud to carry Vision X HID ,LED, and Halogen Replacement Lights.
Finally somebody has met the high demands of the off-road industry. Vision Motor Sports has designed the new HID-6500 to meet every requirement of the off-road market. When you first see these new lights, you will notice a lot of familiar characteristics. Then when you look closer, you will be overwhelmed by the many unique traits they have to offer. Both Models feature an integrated ballast, which means all the installer has to do is supply 12 volts to the light, a 2 wire install.
Click for link
__________________________________________________ _________________________________
Vision-X introduces a first in LED lighting technology with its Xmitter LED Light Bar. Designed for On and Off Road use, each weatherproof low profile light bar produces tremendous light output, with a 12" bar producing 3600 lumens, 100 more lumens than a 35 watt HID while drawing only 4 amps and boasting an astonishing 292,000 hour life span.
Each light bar is manufactured of stainless steel and aluminum for big strength and durability, but measuring in at less than 3" tall and 4" deep, Xmitter Light Bars are perfect for mounting in tight spaces where traditional lights would never fit. Vision Xmitter Light Bars are available from 6" to 42" lengths and come standard with flat surface and tube mounts and rubber shock isolators. Each mount slides along the lower extrusion to match any existing mounting holes and it allows for horizontal and vertical adjustment, this patent pending technology is nonexistent with any other light! Tubing/roll cage mounts are also available in 1.5", 1.75" and 2" black anodized billet aluminum, sold separately.
According to Joe Biro, National Sales manager, "This new Extreme Intensity LED Technology will blow all other light sources away, and they can take quite a beating; traditional Halogen lights will soon be a thing of the past." ;
The LED Xmitter bar is ideal for Dirt Bikers, snowmobilers, ATV and other people looking for a light source for their low power ride. The bar will automatically adjust itself to lower amperage so it can even run off a stator on a dirt bike.
Click for link
LED bars are now in stock but supplies won't last long! These are the newest technology on the market and will be the new industry standard. Get yours while supplies last!
The superwhite series of halogen bulbs utilize a blue glass tube and burn at a temperature of 4500k. Traditional halogen bulbs operate at a temperature of less than 2800k. The results is a bright white light beam with a blue background that is noticeably sharper and brighter. These lights closely resemble HID systems and can be seen from miles away.
All Standard Wattage Bulbs now feature a revolutionary lifetime warranty, and High Wattage Bulbs Feature an outstanding 1 year warranty.
Click for link
If you have any questions feel free to email or call me.
Alon
