fender flares
fender flares
i just put a larger set of tires under my truck, and have a bit of a rubbing problem. i love the look of the truck, and dont wont to change the tire size. its all ready got 6" of suspension, and 3" of body. the tires rub a bit on the bottom of the stock fender trim, or fender flare as some call it, when the truck gets in a bit of a twist. i was considering a set of fender flares. will these help with my rubbing problems? and if so, which brand/style should i go with??? thanks for any help!!!
this is where it is rubbing
so if i was to trim the sheet metal back, and then bolt them into place, it would give me more room??? i had a 77 f250 i put them on, a while back, and we had to trim about 2.5 inches off before bolting them on, i didnt know if the fender flares on the newer trucks were put on in the same fashion or not.
