sticker in the cold?
Old Feb 3, 2008 | 10:02 PM
05extcabflare's Avatar
I got the "f150 online" sticker. Just debating to put it on now (35-45 degrees) or wait until spring. Has anyone put a sticker on the back window while its cold. Would it stick OK on a cold window.
Old Feb 3, 2008 | 10:04 PM
Grafix Ink.'s Avatar
i would wait for warmer weather... you don't need summer.. just make sure its not cold / freezing out.
better safe the sorry. the problem is it might not adhere and or peel off the backing properly.
Old Feb 3, 2008 | 10:12 PM
thanks for the info
Old Feb 4, 2008 | 12:28 PM
my05fx4's Avatar
I went to put a sticker on the back glass just the other day (probably 40 degrees) and it wouldn't stick at all. I hadn't thought about the temperature. In fact the sticker ripped when I was trying to peel it from the backing. But luckily I had two stickers and I was feeling stubborn and determined to get it on there. I used my wifes hair dryer to warm up the glass, stuck it on there and heated it some more before peeling off the outside layer and it worked like a charm. Might be worth a try...
Old Feb 4, 2008 | 05:38 PM
Thanks for the info but going to wait until spring. Although it suppose to nice tomorrow about 65 degree then going back down to 40s on Wednesday and so on.
BTW: Is it f150online sticker.
