Black HID projector head lights???
Originally Posted by XF150 2 EnVyX
make the squirrles hook them up.. lol
but seriously how??
ive had them on for 6 months and don't know what to hook up these two red and black wires
well i hooked up the halos with the parking lights and the projectors and the LEDS i hooked them up to the parking lights.. well what i did was....
the wires that are for the halos i cut a lil and also i cut the parking light wire a lil so i can attach them together u kno waht i mean.... and i did the same with the LEDS with the projectors.. do u kno what i mean or nah..? if u can send me some pictures of the wires from projector lights and the set up where the headlights go on the truck.. its been a while since i did this.. so i will need to see the wires to make sure.. hope this helps lol
Ok.. Lol No Problem By The Way...
Can U Get A Closer Shot Of The Wires From The Halo Wires And The Led Wires.. How Many Wires Is There For Both Tubes Hanging Out From The Bottom Part Of The Headlight.. U Kno What I Mean.. I See 2 Tubes With Wires Coming Out Of Them.. How Many Are There In Each?
FROM THERE I BELIVE..
U KNO HOW IN THE FIRST PIC OF THE HEADLIGHT THERE ARE WIRES FOR THE HALO AND THE LEDS.. WELL MAKE SURE U KNO WHICH WIRES ARE FOR THE HALOS BECUASE I REMEMBER THAT I CONNECTED THE ( IF THERE ARE 2 WIRES FOR THEM I CONNECTED ONE TO THE BLINKER WIRE (WHERE U CONNECT THE PLUG TO THE HEADLIGHT) AND THE OTHER ONE I CONNECTED IT TO THE PROJECTOR WIRE WHICH I BELIEVE IS (Black) BECAUSE THEY WILL TURN ON WITH THE HIGHS AND THE LOW BEAMS ( AND FROM THE LEDS I CONNECTED THEM TO THE WHITE WIRE BECAUSE THEY WILL TURN ON WITH THE REG BEAMS .. THE HALOS CAN TURN ON WITH THE PARKIN LIGHTS(WHICH EVER WIRE THAT CONNECTS TO THE PLUG OF THE HEADLIGHTS) AND THE HIGHS AND LOWS(BLACK WIRE)
thank you, i just don't want to cut wires that i shouldn't cut
not exactly cut completely off i mean like cut the wire shell u may call it... the color part cut a lil so u can actually see the wire and stick the halo wire into there and keep them tight.. do u kno what i mean or should i get some pics showin examples..?
