Anyone have these headlights?
Old Mar 27, 2007 | 01:27 PM
  #46
Bunthy's Avatar
03screw,
let me know how the HID install on these Depo lights go. I was thinking the same thing. But since 2000f150 said the low are still 9007, its going to be hard. I had bixenon on the OEM housing and the pattern was great, an dgreat output. but in the clear diamond housing, it wasn't as sharp, some the light were blocked. Post up some pix on the hid in the new depo housing. If it has little or no glare and still retain oem beam patterns, I might go along with your set up.
Good luck.
Bunthy
Old Apr 12, 2007 | 06:34 PM
  #47
Wookie99F150's Avatar
My headlights should be in Monday! Hopefully will have them hooked up with pictures shortly after.
Old Apr 20, 2007 | 05:17 PM
  #48
03Screwon22's's Avatar
Lights
Sorry Bunthy, but am not going for the DEPO lights, am staying with the stock for awhile, but I did get the HID with the HI/Lo's, it's nice and bright!!!Let me know if your going to put the DEPO's on your truck, peace!
Old Apr 22, 2007 | 11:22 AM
  #49
PROxac's Avatar
HIJACK!
Originally Posted by Memo21687
Originally Posted by SCREWKR
sorry to wreck the thread but memo that grill is awsome I know you said it came with the truck but I gatta find one!
Originally Posted by Vespertine
Sorry, I don't intend to hijack this thread, but...
...While browsing the depths of Google for parts to my 97 lariat I found the grill SCREWKR wanted (memo21687's grill). Hope this is useful, heres the link:
http://www.ex-klusive.com/a-f150991.htm
OK so I LOVE that grill! The one that Memo21687 posted the picture of is not all chrome like the one in the link Vespertine posted or all the ones on eBay though.
Is it available not in all chrome?
If not - Does anyone know if the grill insert is removable (for painting the shell)? Or better yet if it is removable is it available as an insert? (then I would need no paint work!).
If it is only available in all chrome (maybe its all one piece?) how much trouble would it be to prep the shell area for paint? I presume its chromed ABS so would a good sanding be all it would need?
</END HIJACK>
Old May 20, 2007 | 03:17 PM
  #50
mgp32's Avatar
Im thinking about these lights. I cant really tell from the pictures but how clean is the instal? Also, Depo is good brand,correct? Anyone have any leakage problems at all with them?
Old May 24, 2007 | 04:08 AM
  #51
mgp32's Avatar
Bump! Any more info would be great...just about ready to pull the trigger on this but I want to make sure Im not going to have any problems w/ leaking or bad visability or them fitting right etc...
Old Sep 2, 2007 | 03:57 PM
  #52
The only thing you will really have to do is you will have to cut out some of the fiberglass behind the headlights so they will clear, since there is an extra light. Other than that, it's just puttin' in the harness, puttin' them in like the stockers, then aiming them.
