Best headlight bulbs for a '98 F150?
Old Jan 15, 2007 | 12:26 AM
AJC629's Avatar
Good to be back on the forum after a couple years!
The stock headlights are terrible and Silverstars aren't much better in my opinion. Our stock '02 Camry headlights are ten times better, even when I use the fogs on the truck. Any recommendations? I tried some "illegal" 100W/80W that worked great but the wiring showed signs of getting cooked, so I took them out.
Old Jan 15, 2007 | 01:21 AM
snappylips's Avatar
Well, Sylvania has come out w/ Silverstar Ultra bulbs, or you could do an HID
conversion, but I would recommend a headlight adjustment before anything. You may want to consider doing a voltage check @ the headlights. If it's over 0.3 volts lower than battery voltage, run new, heavier wire & a relay--that will bring light voltage up to spec.
Are the housings cloudy?
Good luck w/ it!
SL
Old Jan 15, 2007 | 01:53 AM
gatorade26's Avatar
You might want to consider getting some aftermarket headlights. The Harley Davidson or Lightning styles are popular right now and look pretty good. These units have clear lenses and a nice reflective backing. They look really nice with Silverstars or the "illegal" 100W/80W bulbs (that's what's on mine) or you can try this link: http://www.ford-trucks.com/article/i...r_Brights.html
Old Jan 15, 2007 | 03:43 AM
ws6_guyscrew's Avatar
Thing is the stock heads shine the beam further than clear lensed headlamps, I have OEM SVT Lightning headlamps and noticed they looked much clearer, not goldish like my old headlamps but the old heads had a much greater distance. Even with the Silverstar bulbs that i'm running.
