LT Handle Question
Old Dec 28, 2006 | 11:50 PM
RC4NC's Avatar
LT Handle Question
I am on the verge of ordering the LT Handles for my 05 XLT Screw. However, I do have one last question (or two) before I pull the trigger....
I do not have the keypad on my Driver's side door....However, I did have a keypad security card # in my owner's manual.
Does this mean that the keypad option can be easily added to my driver's side door?
Have any others added the handles with the keypad entry, but did not originally have this option?? And did you get the keypad to work correctly??
I understand that I could use the left rear handle on the front door, but then I would loose the option of using my key to unlock the doors.
Any help would be appreciate??? Also, if this has been discussed before I apologize for the repeat...I did a search but couldn't find exactly what I was looking for
Old Dec 29, 2006 | 12:57 AM
1buddyc's Avatar
Smile
My '06 Supercrew didnt come with the Keypad Driver Door Handle, but I too got a Keypad Security Card with a code when I bought my Truck. I bought a replacement Driver Door Handle with the Keypad and Wiring as part of it and lo and behold, when I took the trim panel off, I found the wire connector inside the door for the Keypad. It was already part of the wire harness in the door. I guess Uncle Henry in his infinite wisdom (lol) decided it would be cheaper to just use one wire haness for all the '06's rather than stock two, one with Keyless Entry and one without. I just swapped the handles and plugged the wire quick-connects together and I had an Illuminated Keypad that locks/unlocks my Truck with my Keypad code....I dont see why it would be any different for an '05 than an '06.
Old Dec 29, 2006 | 06:48 PM
KCSport's Avatar
I know on my 04 the wiring was there for the keypad(along with the security card # in the owners manual) but it don't work. I am told I need to have it programed by Ford. After 3 phone calls and and one visit, it still doesn't work. It's been over a year now, so I might look in to it again.
Old Jan 1, 2007 | 09:59 AM
RC4NC's Avatar
Thanks for the info guys....Let's see, it worked for 1 and did not worked for the other. That's 50/50....Now I am still uncertain on whether to tackle this mod.
Old Jan 1, 2007 | 10:59 AM
welfare wagon's Avatar
I have a similar question about the LT handles. I have the keypad on my handles, by switching to LT's with the keeypad will I lose my currnt 5 digit code or will the same one work on the new keypad handle?
Old Jan 1, 2007 | 11:29 AM
whitecrystal1's Avatar
No the code stays the same. I did the switch with mine to.
Old Jan 1, 2007 | 06:28 PM
95blkcobra's Avatar
Probably stupid, but i have been looking online for the lt handles and have had trouble finding them as a set of 4 with the tailgate as well. I know people have them on here, where did you guys order them from? thanks
Old Jan 1, 2007 | 10:21 PM
RC4NC's Avatar
fastpartsnetwork.com is popular place among this board to order the LT handles....I have a S-Crew and the quoted price is about $293 plus shipping.
There is a couple of others but I can't remember the sites..Expect to pay between $250 to $300 for a S-Crew
Old Jan 2, 2007 | 05:59 PM
95blkcobra's Avatar
ya i have a 04 black Supercrew, I want the 4 doors and tailgate.....do you or anyone else have the part numbers to these??
thanks
Old Jan 3, 2007 | 06:08 PM
CosmoBadoo's Avatar
That's kind of my question, too. I have an '04 Scab and would like the LT handles. I have the keyless entry on mine and have only seen one part number for the driver door handle in the catalogue I have been looking at and was not sure if it already had the punchout for the keyless pad.
Any part numbers would be helpful. Thanks, guys. Great info.
Old Jan 3, 2007 | 08:46 PM
KCSport's Avatar
Now I could be wrong here,but I believe all the LT handles will have the keypad on them. Can't help you with the part numbers. Have you guys tried calling a Lincoln dealer for them?
Old Jan 5, 2007 | 01:40 AM
John Scaro's Avatar
These are the numbers to the handles I just put on my truck
6L3Z-1522405-DP
6L3Z-1522404-DC
6L3Z-1626605-DC
6L3Z-1626604-DC
5L3Z-9943400-AAD
There great looking handles and well worth the money!
Old Jan 9, 2007 | 03:37 AM
bradbriney's Avatar
Do the LT handles come painted already to match your vehicle?
if so does the paint match? how is instalation can you do it yourself?
Old Jan 9, 2007 | 06:04 PM
KCSport's Avatar
They come in the colors that the Lincoln Mark LT trucks do, so if your truck isn't the same color as a Mark LT you'll have to paint them to match yourself. As far as installation, you can do them yourself.
Old Jan 9, 2007 | 07:21 PM
mj2351's Avatar
Ok I have 05 SCab. Which part numbers would be for the drivers side w/keypad, passenger side and taligate?
