hat is your imput on these projectors...
I have them, only mine are chrome. They take an h3 bulb(fog light bulb). I like them but my drivers side fogged up during the summer and the water destroyed the chrome. But that won't be a problem with these ones since theres no chrome. When installed they leave a small gap around the permieter between the housing and the truck which is not that noticeable until your close up to the truck. The halos are ok but not nearly as bright as the new ccfl halos. The low beams put out good light but i've seen better. The high beams are awesome. There pretty easy to aim. Whatever you do don't put hid in these, you WILL get very poor results! Best to put silverstars in these and be done with it. In short, I'm selling mine since I'm doing a true hid retrofit with another pair of headlights I have since I'm not happy with the output of these lights. The halos and leds are easy to hook up. Just connect two red wires and two black wires and connect to your parking lamps or a seperate switch.
Here are mine:
Rob
Here are mine:
Rob
Mine look just like those only I only have 3 LEDs on the bottom for some reason. One difference is my lights are reversed from yours. The projector light is on the high beam line. Do I have my wires crossed?
Thats weird. My projector comes on when my low beams are on and the high beam is on when the high beam is selected. Definately sounds like your wires are mixed up. I think this situation has been covered before. Try doing a search and you should find your answer to wiring these properly.
Well right after posting that thread I decided to go out and pull the lights off and check the wiring. After looking at the main connection I realized that I could in fact switch around two wires. Now the lights are the way they're supposed to be with the projectors as the low beam light. It figures, I bought the damn things off Ebay. You gotta watch what you buy on the site.
Ha, im ordering mine from ebay as well. hopefully they will work and i wont have any probles as it is ebay
NICK
NICK
my cousin bought some for his truck, i dont like them there not my style but to each his own...
the projector should be the low beam and the other light is the high, on his though one of the light assembly's had the wires backwards we had to splice it up and switch some wires around to fix the problem..
the fit was also terrible...
