Modifying Roush Side Skirts
Has anyone modified a set of Roush's side skirts to fit a regular cab F150? I'm putting side exhaust in the truck and his looks perfect except the the length. Roush's are made for extended cabs.
Im sure if you took them to a body shop they could do it pretty easily. fiberglass is easy to manipulate and modify. You may pay extra to have them paint to match, which you were hopefully going to do anyways.
-Patrick
-Patrick
Roush skirts
The skirts are made of ureathane not fiberglass. If they were fiberglass it would be duck soup to modify them. They may have to be cut in a place where seam will show. I have a great body guy and he is not sure the seam can be hidden after cutting,epoxy and bondo. That is why I would like to know if anyone has already done this. The skirts are also notched out to fit fender flares, which I won't be using. I only found 2 companies that make skirts for regular cabs.(StreetScene) which wont work with the exhaust, and DGMotorsports but I don't think that they will work either.
