Quick Help! Clear Corners!
Do these LOOK like the same type of plastic as the headlights on a 98.
The reason I dont like some of the clear corners is because the plastic colors look different, do you think this plastic will match the plastic of the headlight well?
I have these kind of clear corners. They match up pretty well with the stock headlights.(Look at my pics) There are crystal clear corners which do not match at all unless you swap out your headlights also.
