Hid Install
Hid Install
Well here are a few shots of my install of H13/9008 Bi-Xenon HIDS, I bought 10 kits and have listed the others in the classifieds, Install was easy as cake. green/orange wire was lo beams green/black wire was high beam, black ground. I went to pepboys and bought an h4 adapter, the plug came with a white, blue, and black wire, plugged it into the premade harness with the hid kit, spliced the white wire into the high beams, blue wire inot the lo beams, and the black to black. took a mere 20 mins, actually took me more time to get the headlight out and go to pepboys than to install them. here are a few shots, sorry but it was daylight when i did it
So there you have it a real H13 kit with 4 ballast that can run lo and hi beams....
Bi-Xenon low beam on the left, stock on the right.
Another bi-xenon shot
Stock light bulb
So there you have it a real H13 kit with 4 ballast that can run lo and hi beams....Bi-Xenon low beam on the left, stock on the right.
Stock light bulb
I hope your not in Central NY... Because I wouldnt want to drive head on with you.. Without projectors you are going to blind EVERYONE.. and you will make yourself more open for tickets for driving with your Highbeams on... Good luck...
yankeefan, nope red sox fan here
I actual did change out the headlights to projectors also, so not bad still not like what i did on my navigator, I put a set of Sl500 projectors in the housing, they came out real nice.
Where did you get your HID kit from and how much? I have been thinking about adding them to my 04 f150. Do you really need the projector lenses? I have the HID driving lights mounted where my tow hooks were and they appear to be fine.
I bought 5 sets of h13's when I was overseas on work, if you would like to see pictures of how I did it on my mark LT just send me an email to MICHAEL_J_ROBERTS@ML.COM, these are true bi-xenon with 4 ballast that have both hi/lo beams..
