need help installing back-up lights
Old Jul 2, 2006 | 03:16 PM
weedsnager's Avatar
here's the lights i want to put on my 02' F-150.http://www.cabelas.com/cabelas/en/te...k+up&noImage=0
how would i run the wiring to the inside of my truck?
Old Jul 2, 2006 | 05:32 PM
dabird's Avatar
Someone will answer your question about how to get wires to the cab but I would try to find some lights that bolt on rather than attach with tape only. In that location, they will eventually get knocked - better chance of survival if bolted, rather than taped on.
Good luck - I am looking to do something very similar and there are people on this web site that have already done it with great results.
Old Jul 2, 2006 | 06:19 PM
weedsnager's Avatar
i'm going to bolt them on..........i figured out how to get the wires thru the firewall........i have all the wires hooked up to the relay, as the diagram shows that came with the lights.....but i can't get them to work
Old Jul 2, 2006 | 06:32 PM
TRAY's Avatar
Also check out the Body section Electrical Systems thread for back up lights, SCULLY has a wiring diagram that may help. I also posted and you can see my gallery for the lights.
Sounds like you have a bad ground somwhere. Check your connections.
Good Luck...
