Harley Davidson Valance will it fit?
Old May 30, 2006 | 12:59 PM
stamp32's Avatar
I have got a 2002 F150 reg cab. I was wanting to know if the Harley Valance and foglights will just bolt on the factory brackets for is it different.
Chris
Old May 31, 2006 | 07:08 AM
tj03f150's Avatar
it sure will! all you gotta do is remove the stock lower valance you have now and replace it with the new one.. to use ur factory fog lamp setup swap out ur current headlight switch with one that says "pull for fogs" with the headlights in the on position. hookup the existing fog light harness's to ur harley fogs (if they are not 9145 u may need an adapter like the stx has which makes the plug much smaller) and then ur good to go!
