fog lights
Old Apr 18, 2006 | 05:20 AM
COORS73500's Avatar
Lightbulb fog lights
I need help, My truck did not come factory with fog lights. It did however come with black plastic knockouts where the fog lights go, and the wiring is all there. Where can I get a set of factory fog lights for a 1998 f-150?????
Old Apr 18, 2006 | 12:43 PM
SlammaJamma's Avatar
Ebay/Ford itself.
Old Apr 18, 2006 | 01:30 PM
iwashmycar's Avatar
there are quite a few sets on ebay...they have crystal clear sets too
Old Apr 18, 2006 | 05:01 PM
kingfish51's Avatar
With luck, the wiring harness should already be there. There will be a plug attached to the front clip that supports the radiator, somewhere behind and below each headlight. You will need the fogs, and the I believe the switch itself. When I purchased my kit when I had my 98, it came with the fogs, a wiring harness, and the switch. Only needed the fogs and switch back. This was purchased from Ford.
Old Apr 18, 2006 | 10:21 PM
ws6_guyscrew's Avatar
http://search.ebay.com/search/search...rclo=&saprchi=
just click that and look but do you have the fog switch? should be with with the headlights , turn on heads & pull back
Old Apr 18, 2006 | 11:21 PM
COORS73500's Avatar
Question
hey kingfish,,, how much did you pay for your light kit???? and for everyone else, yes I have the right light switch already. I just need the fog lights only.
Old Apr 19, 2006 | 08:43 AM
kingfish51's Avatar
Sorry, I can't remember. Been too many years. I had bought the truck off the lot new and put the fogs on within a few months. I know it wasn't cheap at the time, but can't remember the price.
Now if you can find a 97 or 98 that has the fogs and was rear-ended, you should be able to take the mount, lights, and wiring to the harness (from bulb to cross member) and use those.
