Corner Lights
Corner Lights
Found these on ebay. I think they are really cool. Anyway, how do you remove the old ones?
http://cgi.ebay.com/ebaymotors/97-00...41432540QQrdZ1
Corners
I agree, unless you have the black heads, those may not look as sharp. I put clears on my 03 Supercrew and the daughter's 99 RegCab, and we both get about them a lot. I put the amber bulbs in mine, and it is brighter than the factory corners now.
To remove them there is a screw on each side, one only. Look right above the bulb socket and there will be a small torx head screw, take it out, slide the corner out towards the front, twist the bulb out, reverse the order, about a 15 minute job unless you drop a screw and have to look for it like I did!
good luck
good luck
