LED tail lights
Old Jan 21, 2006 | 07:59 PM
Screw-Jake's Avatar
LED tail lights
Anyone have these LED tail lights? I have them and they are a great look but am having a problem with them. When depressing the brake they go from bright to off then back to dim when the park/headlights are on. also the same with the blinker. They do not blink fast or anything because it comes with an LED relay attached. I had the smoked pair first and they worked for about a week or so then I got this problem, so I sent them back and bought the red lense pair and still have the problem. My stock tail lights worked fine before and after so I do not get it unless the blinker relay is bad some how but like I said the stock ones work fine. If anyone else had this problem please let me know how you fixed it, or if you know where the relay is and if there is a different one I should use. Here is a pic and link to the lights
http://www.autotoyaz.com/autotoyaz/folta.html
