Changing headlights,need help.
I just bought side and clear headlights,there are two pins on each head light that you pull up on,if I pull up on them what else do I have to do to replace headlights.I don't want to get over my head on this.
Is there a how too on this subject that can help me.
Thank You
Thank You
After those two "slide pins", you should be able to pull them out enough to get the bulbs out of the housings. They just pull straight out of the front of the truck. The side markers are held in by one phillips head screw.
You'll want to make a note of how your old ones are aimed before you replace them. It makes it easier to make any fine adjustments if you get the adjustments roughly in the same place to start with.
