installing headlights & corners.
Old Nov 8, 2005 | 01:30 AM
Joe Styles's Avatar
what all do i have to remove to install new clear lights and corners on my truck.or if there is a how to where can i find it.
thank's
Old Nov 13, 2005 | 02:02 AM
casualtr's Avatar
pull the screws off of the top and bottom of the grill, don't forget to get the two screws behind the markers, after that just pull the tabs on the headlights and slide them out.
Old Nov 17, 2005 | 11:56 PM
The_Dude's Avatar
I've been down this road as least 3 times. What truck do you have? All Fords require removal of the grille for headlights/corners. I can prolly guide you the whole way. I own a 2000 Ford F-150 XLT. I use Elegante headlights and corners by TYC. Drop me a line.
Old Nov 18, 2005 | 08:57 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
???? I have been doing it wrong for years then? I have never had to do anything to remove headlights on my 98? Pull the tabs up under the hood, reach behind the headlight, and push out on the plug? The corners you have to remove the one screw on top under the hood, and then hook your fingers around the back edge, and pull it out? Why does the grill have to be removed? I'm curious?,,,,98
Old Nov 26, 2005 | 11:34 PM
The_Dude's Avatar
Lol. U have a good point. The headlights can be removed without taking off the grille. But the new aftermarket headlights cannot be alligned properly unless you DO remove the grille. Imagine putting in new healights and try some night driving only to reliaze that ur beams are to high, to low, or just all f*cked up. Most my truck "knowlege" comes from trial and error; that and i work at a used car dealership. It took me 20 minutes to remove my grille and install new headlights/corners, removing the grille assembly also makes the job easier and less risky towards breaking the housing allignment plastic-ware.
Old Nov 27, 2005 | 01:03 AM
98SCREAMER's Avatar
Talking
Take out old headlights, set them beside new headlights. Turn the adjusters on new headlights until they match up as close as possible to the old ones. Install new headlights ,,,,98
Mine were close enough to pass, anyway.
Old Nov 29, 2005 | 09:31 PM
WhitecoltF150's Avatar
Cool hmm
well arent those guided adjusters meant to guide the headlight into the proper position? just a guess......
Old Nov 30, 2005 | 11:35 AM
bigtruck311's Avatar
took me all of 30 min to put in my headlights and corners and removing the grill was not nesasary for my lights i was able to get them agjusted perfect with only the rear and side agjustments, it is easy job good luck
Old Nov 30, 2005 | 11:38 AM
here is a pic of mine,
Old Nov 30, 2005 | 11:58 AM
150Lariat2000's Avatar
Big truck you got the same headlight from me... Got them off ebay and very easy to install.
Old Nov 30, 2005 | 02:20 PM
a freind gave me the lights and corners for doing some tranny work for him, do you know what kind they are?
Old Nov 30, 2005 | 02:26 PM
Actually I forget, I will look when I get home. I have the box there. How long have you had them on??
Old Nov 30, 2005 | 04:20 PM
i have had them alittle longer than a year maybe year and a half, my budy had them for only a month before he went with some expensive HID lights
Old Nov 30, 2005 | 05:44 PM
Nice, I have had mine for a little over 3 months. I got them as soon as I bought my truck. I will post pics of my truck probably after Christmas after I finish doing work on it.
