HELP! Steering wheel lights!
Old Apr 7, 2001 | 03:35 PM
thepawn's Avatar
Question HELP! Steering wheel lights!
The light on my on/off switch for cruise control is out. How do I open this thing up to change it? I havn't been able to figure it out.
Thanks,
Daniel
Old Apr 8, 2001 | 11:08 AM
Firezap's Avatar
Cool
Pawn;
On the back side of the wheel directly behind the switches are little disks. Pop this disk out and the bulb is in there.
Ed
GOLD RUSH
'99 F150 XLT SC SB 4x2 Harvest Gold
Factory[*]5.4[*]3.55 limited slip[*]Trailer towing package[*]In-dash CD player
Aftermarket[*]Ford Beanie bear[*]Slip on extender mirrors[*]Powerstop brake controller[*]Covermaster C1000 topper with wing[*]BugflectorII[*]Ventvisors (front&rear)[*]3 www.f150online.com decals[*]Ford Lumi Logo[*]Steelhorse Billet grill[*]Ford hitch cover[*]Yellow wire loom[*]Hyper White head light bulb[*]Fender badge on tailgate[*]Painted to match AVS slotted taillight covers[*]Ford system 4 alarm[*]Clear turn signals[*]"Blazer" strip reflectors under tailgate[*]FORD script antenna painted to match[*]Cup Holder courtesy lights[*]IonOptics driving lights as reverse lights[*]12 Volt power outlet in bed[*]Power port/Cigarette lighter courtesy light[*]4 Driving lights in grill[*]Next who knows???
<A HREF="http://www.firezap.url4life.com" TARGET=_blank> </A>
<A HREF="http://njf150truckclub.homestead.com" TARGET=_blank> </A>
firezapper@f150world.net
[This message has been edited by Firezap (edited 04-08-2001).]
Old Apr 8, 2001 | 06:34 PM
thepawn's Avatar
Thumbs up
Thanks...for abotu a week I was tryiing to remember if it actually had a light in it or not and wether I was just nuts.
Dan
Old Apr 9, 2001 | 10:44 AM
Shark99's Avatar
Post
ThePawn-
The two "disks" on the back of the steering wheel...they cover the two bolts that hold the airbag on. You can remove them (the bolts, 8mm), but dont unplug the airbag (connector on the bottom) you can unplug the horn circut (connector on top of airbag) However, If I recall, The bulbs, are actually very small Led's mounted in the button itself. something that wouldn't easily be replaced by itself. The buttons and related wiring are a "single unit" Had mine replaced when the leather steering wheel was installed (lights were the wrong color).
2000 XLT Silver 5.4L SC 4X4 ORP 157"wb Ford Floormats, MudFlaps,Cabin Air Filter, lighted emblems, lighted interior door handles(all 4) Chrome Grill (4x2 style), Diamondplate bed caps, Pro-Tech tool box, Air Box mod, Muth Heated Signal Mirrors, Custom Gauge Pod-(water temp, trans temp)
Perma-cool 8" Electric Trans Cooler Fan, (2) Perma-cool 14" electrics, Superchip (flipchip), Map lights in overhead-rear pass, tinted windows, back up lights.
Old Apr 10, 2001 | 02:49 PM
thepawn's Avatar
Post
Shark99,
Thanks, I found this out the hardway. I took the airbag off and stuff and remove the module, pulled up the rubber top and found no bulb! Eep! Now I can't get the rubber piece to go back in.
Well, when I take it to the dealer for the doorcrack, I'll get him to fix it.
Daniel
Old Apr 10, 2001 | 05:14 PM
HarleyGuy's Avatar
Talking
When mine went out in my wife's Explorer, they replaced the whole switch. Couldn't just replace the led bulb. Cost around $50. Expensive bulb, but that is the only thing that has ever gone wrong on that car which now has 75K on it. Can't complain, too much.
2000 F150 Harley-Davidson: Superchip, K&N FIPK
Hard Tonneau, Hidden Hitch, 2-Meter Rig (KG0UK)
'99 FLHRCI, '95 XLH
