Nerf Bar Help - Modifying to fit.
Old May 17, 2005 | 01:05 AM
awagawe's Avatar
Hey guys,
Just got my new nerf bars today, i went to put them on and the holes do not align up, has anyone else had this problem? It doesn't look like it would be too hard to drill some new holes. I have a 2003 F150 exteded, and it says that the bars are for 97 - 2003 extended. 2wd ... anyways thanks for the help.
Old May 20, 2005 | 12:07 AM
cklap78's Avatar
I just had my nerf bars installed...I had the same problems at first where the holes on the chasis dont match the screw bracket they give you. I took it to where I bought it from and the guy showed me how do do it...
Ok...Lie on the ground facing up....slide underneath the truck where your door is.....you probably are lookin straight at the chasis by now.....now turn your head down and look towards the bottom of the door.....you'll see some rubber boots to take off..they are covering the holes where u need to put the brackets on. you do not mount the bars onto the chasis..u mount is on the same side as your door on the bottom.
