Billet Grill installation help!?!?!
while helping a friend install a billet grill in his 00' f-150 we were unable to remove two metal clips on the underside of the grill housing...because of that we were unable to get the new grill installed....please help with ho to remove those clips..thanx
bubba joe,
you have to reach in thru the hole in the bumper with a flat head screw driver and push up on the clip as you pull on the grille. Easy does it though, 'cause you don't want to damage the facia that surrounds the grille.
hope this helps!!
Paul D.
98 F150 Supercab XLT 4.2L
Oxford White
Mods:
K&N Filter
Steel Horse Billet Grille
Window Tint
Future Mods:
Superchip, Catback Exhaust, Interior Wood Trim Kit, Roll Top Tonneau Cover
hope this helps!!
Paul D.
Oxford White
Mods:
K&N Filter
Window Tint
Future Mods:
I suggest that you remove the bumper. It will be a lot easier then trying to remove the plastic rivets that are on the fender.
As for the metal clips I had no trouble with them just pull straight out. It takes quite a bet of force but they will pull out. Just remember to put them back on before you reinstall the grill.
GOLD RUSH
'99 F150 XLT SC SB 4x2 Harvest Gold
Factory[*]5.4[*]3.55 limited slip[*]Trailer towing package[*]In-dash CD player
Aftermarket[*]Ford Beanie bear[*]Slip on extender mirrors[*]Powerstop brake controller[*]Covermaster C1000 topper with wing[*]BugflectorII[*]Ventvisors (front&rear)[*]3 www.f150online.com decals[*]Ford Lumi Logo[*]Steelhorse Billet grill[*]Ford hitch cover[*]Yellow wire loom[*]Hyper White head light bulb[*]Painted to match AVS slotted taillight covers[*]Ford system 4 alarm[*]Clear turn signals[*]"Blazer" strip reflectors under tailgate[*]FORD script antenna painted to match[*]Cup Holder courtesy lights[*]Next who knows???
<A HREF="http://www.firezap.url4life.com" TARGET=_blank>
</A>
<A HREF="http://njf150truckclub.homestead.com" TARGET=_blank>
</A>
firezap@f150fanatic.com
firezapper@home.com
[This message has been edited by Firezap (edited 09-17-2000).]
GOLD RUSH
firezapper@home.com
OK. I know this should be simple but how do the screws come out in the plastic inserts on the shroud under the hood? I was able to unscrew a few of the screws but the other ones just spin. I was afraid to pry to hard.
I love plastic parts.
Tim
Tim
Pull hard...
Push hard...
Repeat as neccessary...
Rich
1999.5 SVT Lightning - Red. Super Chip. K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, AIM 2" Drop, Trenz billet grills, Piaa 9007 Super Whites, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt...cs/SigPic1.jpg
2001 PT Cruiser - Limited Edition
1999.5 Expedition XLT
[This message has been edited by TampaBayLightning (edited 09-17-2000).]
Push hard...
Rich
Bubba Joe,
Had to take my front grill off yesterday to do some touch up on the fender.
For removal of grill with ease…
0) Tape up top fender edges to prevent scratches upon removal of grill
1) Remove retaining screws & front upper air deflector
2) Remove headlamps and corner lamps
3) Remove (carefully) pin type retainers under grill. 4 on each side
4) Remove grill screws (10 total)
5) Reach from above between radiator and grill to release 2 retaining clips. No tools required. May be pushed out by hand.
6) Slowly pull grill forward.
To install…do the reverse
Hope this helps.
"Silver Steed"
Stock '00 XL
Silver flareside sprcab, 5 spd, 4.2L V6.
Email:
ferdi_n@f150driver.com
ferdi_n@hotmail.com
[This message has been edited by slvrsteed (edited 09-17-2000).]
Hope this helps.
"Silver Steed"
Stock '00 XL
Email:
ferdi_n@hotmail.com
Tim56Ford,Unfortunately if the screw inserts does not screw off you will have to insert two small flat-heads on either side of the retainer and pop it out. Don’t worry, its re-usable. The only thing is you will need to be less-**** than I as you will mar the plastic. Hope this helps.
"Silver Steed"
Stock '00 XL
Email:
ferdi_n@hotmail.com
"Silver Steed"
Stock '00 XL
Email:
ferdi_n@hotmail.com
