Any comments on Steel Horse Billet?
Does anyone have any pics or problems with the Steel Horse brand billet grill? After seeing the problems people had with the Wee1 product, I am concerned. Thanks
I have one in my 97 F-150 4 w/d i got mine through JC whitney the upper was around $75.00 and the lower bumper grille was around $50.00. I have had no problems with mine at all! it costs a lot less then the others and it is a very high quality good made grille. and i would recomend this grille to anyone! as far as the install if you have a 4 W/D it is fairly easy the factory center grille is held on with plastic tabs you just cut them and the center comes right out! but if you have the 2 W/D it is pretty hard and time consuming cause you have to cut the factory grille out this is were you need a steady hand and a dremel tool or a air cut off tool to cut the center grille out! hope this helps!!!!!
Here's mine
I love it, the factory came out very easy. Just I recommend you remove the bumper first because the filler strips under the grill are a pain to get out. I'm thinking of getting the lower, does anyone have a 99/00 with the lower?
Aenea
GOLD RUSH
'99 F150 XLT SC SB 5.4x2 Harvest Gold
3.55 limited slip
Trailer towing package
In-dash CD player
Ford Beanie Bear
Slip on extender mirrors
Powerstop brake controller
Covermaster 1000 topper with wing
BugflectorII/Ventvisors (front&rear)
3 www.f150online.com decals
Ford Lumi Logo
Steelhorse Billet grill
Ford hitch cover
Yellow wire loom
Hyper White 9007 head lights
aeneamarie@f150gal.com
[This message has been edited by aeneamarie (edited 07-07-2000).]
Aenea
GOLD RUSH
3.55 limited slip
In-dash CD player
Ford Beanie Bear
Ford Lumi Logo
Ford hitch cover
Yellow wire loom
