Running lights/Power rear window
Old Mar 19, 2000 | 02:31 PM
Indigo's Avatar
Question Running lights/Power rear window
I've always been kinda partial to a nicely lit up truck. Not to the extent of an 18-wheeler, mind you, but nice running lights, etc. Has anyone ever seen, or have installed the roof mounted lights that you can get on the F-250's on an F-150? Cost? Difficulty?
Also, has anyone ever installed a power back window? I have seen a "PowerSlide" model for around $500, but I know there is also one where the entire window drops down vertically as opposed to a center section of the window opening laterally like the PowerSlide. Anyone?
Thanks!
1999 F-150 4x4 SuperCab, Deep Wedgewood Blue, ORP, 4-Wheel ABS, Loaded, Flowmaster 50 series, K&N, Tint, Super-White headlights, Westin Nerf Bars, Toff Spray-On Bedliner, Pioneer DEH-P3000 and TS-A6815 speakers, ADS PQ/8 amp.
Old Mar 19, 2000 | 03:50 PM
ROUSHFAN-1's Avatar
Post
where have you seen the power slider?? i know someone looking for one...
Old Mar 19, 2000 | 04:54 PM
Marv1's Avatar
Post
RoushFan...try Custom Concepts out of Lincoln, CA
HTH, Marv
Old Mar 21, 2000 | 07:53 PM
F150BOB's Avatar
Post
Try this link.
http://www.crlaurence.com/newcrlsite.../slidelob.html
This is the one I have and it works great.
BOB
97 F150 Lariet 4X4 SC Everything except ESOF plus Line-X Bed Liner, Power Rear Slider, 16X8 Chrome Centerline Starfires, 305-70 Goodyear AT/S, Alpine Alarm, Deflecta-Shield Sportrends Running Boards, Edelbrock IAS Shocks, a new "no piston slap" 5.4, and a new "no-crack" door.
Old Mar 22, 2000 | 10:40 PM
Black 98's Avatar
Post
The worst thing about the power slider is that they require alot of maintnance. They need to be cleaned and the cables have to be lubed often or they will jam.
The roll down type are real bad. I would definately not recomend them to anyone. They take up alot of room and dont work vey well. They are also hard to get parts if you need them.
Stick to the power slider and just take care of it. I work on them all the time when people just let them go and they are all messed up. The cables are usually stuck and they keep trying to run them and end up messing up alot of stuff. Even the motors.
Black 98
Black 98 4x4,4.6l Triton Dark tinted windows, bedliner, factory molded splashguards, K&N filter and 3in fresh air airbox modifications,B&M Shift Plus,factory fogs added along with Blue bulbs and Auto headlights, spray-on door sill protectant, Painted (and chrome) throttle cover and other underhood components.
Old Mar 23, 2000 | 04:54 PM
Indigo's Avatar
Talking
Thanks Black98 and F150BOB!
Old Mar 23, 2000 | 06:40 PM
Freezer's Avatar
Post
As far as the power rear slider goes, Ford also makes a power rear slider kit. In fact, that is even an option on 2000 Lariats. It is part of option 63L (Lariat Upgrade Accessories Pkg), cost $995.
1999 Lariat SuperCab Flareside, Amazon Green with Silver trim, 5.4L, 4x2, 4 wheel disc/ABS, 3.55 limited slip, towing package, fog lamps, sliding rear window, captains chairs, keyless entry with alarm, spray-on bed liner, bug guard, and K&N. http://www.csc.calpoly.edu/~bfriesen/truck.html
