Electric Power interupt?
Old Dec 28, 1999 | 12:44 AM
Kenster's Avatar
Post Electric Power interupt?
On a Taurus Wagon we bought new in 1991, the Ford Dealer installed a power kill system that was controlled by inserting or removing a computer coded "key" which slid into a receptical under the dash. With the key removed, the circuit was broken and the car could not start. A simple and effective deterant. Is there such a product, or one similar still on the market, or some other simple kill switch? I don't really care for the remote control keyless entry/alarm/kill switch things because I don't like carrying the unit in my pocket.
Any suggestions?
1997 F150 XLT-STX, Reg. Cab, White, 4.2L, Auto
-It's a beautiful Thing!-
Old Dec 28, 1999 | 12:54 AM
rcantu's Avatar
Post
It's basically a kill switch. Just make your own and save some money
Robert
99 F150 Xtracab 4X4 XLT
5.4 liter Flairside
3.73 gears
all stock for now
rcantu's Avatar
Post
Robert
5.4 liter Flairside
3.73 gears
all stock for now
Old Dec 28, 1999 | 01:07 AM
Kenster's Avatar
Post
Robert, I am neither a mechanic nor electrician, but I can follow simple directions. Can you tell me how I can make a kill switch? I assume you cut or splice into a wire, (starter cable?) but how do you hook up the switch.
Thanks,
Ken
Old Dec 28, 1999 | 10:55 PM
rcantu's Avatar
Post
well, there's 2 ways. Both require cutting the ignition or starter wire under the dash. The easiest is using a toggle or momentary switch and wiring it between the cut wire. There's another way with a relay but I have to look at some notes.
If you want one of those "chip" things, I can get it for you. This way you can just mount it below the dash and have that little red LED as well. I know it'll be less than the $200-$300 the dealer will take you for.
I might be able to get one those units that you just swipe across vs. inserting a chip. email me privately if you want to discuss it further.
This holds for anyone that is interested.
Robert
rcantu@aol.com
5.4 liter Flairside
3.73 gears
all stock for now
