? Bugflector II
Old Nov 7, 1999 | 09:52 PM
Greg H's Avatar
Question ? Bugflector II
Just purchased a Bugflector II and was wondering if anyone else had trouble closing their hood after installing this brand of deflector?
I first used the adhesive, to mount for proper fit and postion, before I placed the screws. Now I can't get my hood to close! Any ideas or suggestions?
Old Nov 8, 1999 | 05:01 PM
cphilip's Avatar
Post
No mine closes fine. Mounted it same as you did. I belive there are two stops that you might have to screw down a bit. Yours might be too high. They are on the lip just above the radiator shroud, one one each side and appear to be two round rubber bumpers on a threaded bolt.
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels and the 4X4 decals, MODs so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps.
Old Nov 8, 1999 | 11:58 PM
Y2K 4X4's Avatar
Post
I use to own a 97 F-150 and when I tried to install my Bug Deflector II, I had the same problem. I adjusted the hood stops, but to no avail. I now have a new F-150 and with it a Ford bug deflector. This was definitely the way to go. You use the existing holes for installation and it fit perfectly.
2000 F-150 4X4 Ext Cab, Island Blue, Off Road Pkg, LS 3.55, 5.4L V-8
Old Nov 9, 1999 | 07:11 AM
bono's Avatar
Question
Y2K 4X4,
Which of the Ford deflectors did you purchase(Wraparound or Aero). They sell two types on their iCollection web page. Also, does the deflector use the rubber bumpers attached to the hood and does the top lip of the deflector curve up or is it parallel to the hood. Thanks in advance for the info.
Bono
[This message has been edited by bono (edited 11-09-1999).]
Old Nov 9, 1999 | 10:59 AM
Indyfan's Avatar
Post
I can't really offer too much in the way of suggestions without looking a it, I installed it the same way you did and it worked the first time. All I can suggest is look to see where the interference is (scratches or rub marks on the truck or the shield) and then try to adjust it in or out. Good luck.
1999 Lariat Super Cab, S.B. 5.4L, 3.55 LS
and everything but the leaky slider window.
Bright red w/ gold 2-tone, Leather Captain's Chairs
Mods: Duraliner bedliner, Bugflector II, Hide-a-hooks.
& a leeetle chrome tip on the exhaust.
Old Nov 11, 1999 | 12:05 AM
Y2K 4X4's Avatar
Post
Bono,
I guess I got the wrap around. Honestly, I'm not sure since it was a gift, but it extends from fender to fender and is the more expensive one of the two. I think it cost around $70. A good bit more than the Bug D II from my recollection, but well worth not having the hassle. Again, it was a gift. It does have the hood bumpers (with a template to make sure you place them correctly) and it does curve up. It's very similar to the Bug D II, except for it has a place on either side (where the hood body lines changes)where a little portion of the hood is exposed. It's hardly noticeable and it doesn't bother me.
I hope this helps.
