Easiest way to get driver side hedlight bulb out
Your Owner's Manual shows you exactly how to pull the entire assembly out. Be very careful not to bump the adjuster rods (getting them out of alignment). Also be careful when you slide the assembly back in making sure that the adjuster rods slide down their intended paths. If you find your headlight aim off after installing a new bulb, this is where your problem is.
All of the above work...
To make it easier on yourself, remove the side marker/turnsignal assembly. This gives you three times the room to work when removing the headlight assembly.
-RP-
-RP-
