Taillights for '03 Screw
Old Oct 8, 2003 | 08:02 PM
JasonJ's Avatar
Question Taillights for '03 Screw
Hey all, any idea if these lights off of Ebay will work on my '03 Screw? They say the fit the '97-'00 Flareside which I think has the backend as mine. Any help would be appreciated.
Thanks!
Old Oct 8, 2003 | 08:22 PM
eposey's Avatar
I don't think that they will...
The older tails used a 3-bulb system I believe. The newer ones use a 2-bulb system.
Post the link to that ebay ad.
Old Oct 8, 2003 | 11:34 PM
JasonJ's Avatar
Whoops, forgot that part...
actually these say for '01-'03 F150 but doesn't specify Screw or Flareside.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2435969568
Old Oct 8, 2003 | 11:46 PM
eposey's Avatar
As long as the years match up. Flareside and Screw are the same thing...
Old Oct 8, 2003 | 11:47 PM
eposey's Avatar
By the way...
I don't know what tails you're thinking of off of Ebay but whatever you do, don't get the Black Chrome Euro Tails!!!
Old Oct 9, 2003 | 12:42 AM
JasonJ's Avatar
why not, what's wrong with the Black Chrome Euro's? Those were the ones I was looking at.....
Old Oct 9, 2003 | 02:16 AM
JasonJ's Avatar
Lightbulb
Found your other post Posey, I see your frustration. I may still be willing to roll the dice if they look good on a Dark Shadow Gray truck. What the hell, I have nothing to lose except $60 plus tax and $20 shipping. Huh, guess that is a lot to lose.....
Old Oct 9, 2003 | 11:20 AM
Lonster's Avatar
Jason,
YES, they will fit. I just put them on my '03 Screw and they look good with my black paint.
A couple pointers tho....
They don't come with any instructions.
You will have to shorten you mounting screws about 1/4 inch, so they don't "bottom out" and strip the mounting hole. I also recommend you put a drop of silicone in the screw hole to help hold against vibration.
The second item I found was the new gaskets that are supplied are to thin. The bulb sockets are loose if you use only one gasket. I had to double up the gaskets (stock one and one supplied with lights) to get a tight fit. It is very tight.
Last, the right side housing has the stop/turn socket hole cut wrong. It is near impossible to get the socket in. I had to remove the wire plug, install the socket and physically turn it past the stops, to be able to get the plug back on.
It is possible but take your time and be careful.
Definitely worth the effort.
Lonster
Old Oct 9, 2003 | 12:08 PM
JasonJ's Avatar
Thanks for the tips Lonster, sounds fairly easy. I will probably get them this weekend.
Old Oct 9, 2003 | 06:06 PM
eposey's Avatar
Are your's leaking water? Mine have condensation all inside of them (on the right side).
They would look awesome on a dark shadow grey truck, just the quality sucks.
Definately some nice looking tails though.
Honestly I would advise you against them. I am already planning on getting the bermuda black tails pretty soon.
Old Oct 9, 2003 | 06:49 PM
lifeguardjoe's Avatar
Do you have a website link to check some pics out? IF so do they make some for styleside?
Old Oct 9, 2003 | 11:59 PM
eposey's Avatar
Check that other thread I started...
I think it is towards the end of the black headlights post and someone gives a link to them. Stylinconcepts also carries them. I have seen black ones for styleside before.
Old Oct 10, 2003 | 01:56 AM
Lonster's Avatar
No, mine don't leak or show condensation. But I used both washers (one black and one white) on all 4 sockets. If you use just one washer (black or white) it won't make an air tight seal. When the lights are "on" the hot air is forced out and when they are turned "off" the cold air will creep back in, causing condensation.
Either that or you have a crack in your lens.
Do both show condensation?
Lonster
Old Oct 10, 2003 | 06:12 PM
eposey's Avatar
Just the right...
