Phase II of System need Help
Old Jan 28, 2002 | 12:42 PM
98STXV8's Avatar
Current system:
Clarion DXZ715 HU
4 Infinty Ref. 5x7 front doors and back
1 Infintiy Perfect 10" custom enclosure
RF Power 360a2 bridged
Phonenix Gold 4 Gauge
New system
Q Form Kick Panles with Infinty Comp 5.25
1 Infinty Perfect 10"
RF POwer 360a2
Clarion 12 disc changer
now for the question. How do I wire the new amp to push just the new sub? The current amp is setup for the one sub. But how do I wire the amp? and How do I wire the componets to run with the 5x7's
Old Jan 28, 2002 | 05:42 PM
1995xcr600's Avatar
What year is the amp? If it is a 2001 here is the link to the owners manual at the Rockford site.
http://www.rockfordfosgate.com/ezcom...erAmps_MAN.pdf
If not, the site has a searchable database. Hope this helps.
JGD
Old Jan 28, 2002 | 09:01 PM
LLoverCrazyJay's Avatar
Check this site out...
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Look along the side and find.. Series/parallel basics or Amplifier bridging
I have found this site has ALOT of information! Hope this helps!
Old Jan 30, 2002 | 09:10 PM
isaiah4031's Avatar
Need more info. Are you saying that you are adding a second sub and amp? If so, I would run the front 5x7 and comps to one amp parrallel at 2ohms and keep the gains down. Then I would get a class d amp to run the 2 subs at 2ohm load. Bridging a 360a2 to 2 4ohm subs is sure death for the amp. It can not handle that load without doing damage down the line.
