is this amp to much for this sub
Old Dec 14, 2012 | 11:23 PM
West Tx F150's Avatar
Here are the specs for the amp and I will be running one single 12. Specs for both below and I already have the amp
RENEGADE S AMPLIFIERS
REN 850 S
Monoblock
• 1 x 225 Watts RMS into 4 Ohms
• 1 x 425 Watts RMS into 2 Ohms
• 1 x 450 Watts Max. into 4 Ohms
• 1 x 850 Watts Max. into 2 Ohms
• MOSFET Power Supply
• RCA In- and Outputs
• 2 Ohm Stability
• Lowpassfilter 40 - 150 Hz
• Subsonicfilter 15 - 55 Hz
• Bass Boost 0 - 12 dB
• Bass Remote Controller
• Dimensions: 255 x 55 x 250/280 mm
Sub is a Boston acoustic
frequency response 20-350 Hz
Power range (watts rms) 50-200
Maximum wattage 400
Sensitivity 88db
Impedance 4 ohms
Old Dec 15, 2012 | 12:36 PM
TK5's Avatar
TK5
That amp will be perfect for that sub
Old Dec 15, 2012 | 12:41 PM
Thanks tk5
Old Dec 16, 2012 | 03:18 AM
pizzaman711's Avatar
Like TK5 said, the amp looks like it specs out good to the sub. Never heard of the brand before though, is it a new brand just coming out?
Old Dec 16, 2012 | 10:29 AM
Not quite sure pizzaman. I have had the amp a little over a yr now and i know somehow they are tied to rockford.
