will this setup work?
Old Dec 28, 2010 | 10:22 AM
biggdave92's Avatar
I have an 05 scab. My plans are:
Atrend single 10 box for under the rear seat
JL 10W1V2-4 10" sub
JL 500/1 amp (do i need this much power?)
Stock head unit
Stock door speakers
I will probably upgrade the door speakers in the future. I really dont want to mess with the head unit. I like the factory look. thanks for any help!
Old Jan 9, 2011 | 01:09 AM
BL4CK3D0UT's Avatar
The amp has 40% more power than the sub needs. If you do use that, make sure your gain is low so the sub won't blow
Old Jan 10, 2011 | 06:34 AM
Norm's Avatar
You still set gain correctly and use your volume control to prevent damage.
Old Jan 10, 2011 | 02:02 PM
Titan357's Avatar
these look good imo.
Old Jan 10, 2011 | 08:59 PM
helotaxi's Avatar
If you're dead set on a JL amp, the 250/1 is plenty of power for that sub and significantly less expensive as well. IF you're open to different brands any amp that can give you around 200-300 watts would be fine. Getting a small 2 channel and bridging it would be the least expensive route by far and would not sacrificing any performance.
Old Jan 11, 2011 | 03:54 AM
Low_e_Red's Avatar
Yea, pull back on the reins a decent bit on this one. Youre going to need an amplifier that puts out between 125-175W RMS @ 4 ohms.
Old Jan 13, 2011 | 11:29 PM
Ianh's Avatar
If you want to keep the stock headunit but want some flexibility down the road, take a look at the JL audio clean sweep system
Old Jan 14, 2011 | 01:37 AM
mSaLL150's Avatar
Get a 4 channel, bridge 2 channels on that sub and run the other channels on your front speakers.
