Switched power lead for amp
Old Sep 11, 2010 | 12:26 PM
SSCULLY's Avatar
Originally Posted by F 1Fiddy
Is that switched F41 fuse in the fuse block at the pass kick panel? I would like to find that one. ....<snip>....
Yes, the cab fuse panel is in the passenger side kick panel, owners manual page 316. Not hard to find at all, the cover has the numbers on them.
....<snip>....I found a yellow wire down there that I tapped into for my remote wire. If I had one that would stay hot until the door opened would be even better....<snip>....
You are not looking for a wire, you are looking for fuse slot 41 to install an Add-a-fuse in.
