2 Ohm or 4 Ohm
Old May 1, 2010 | 04:07 PM
deerhunter0743's Avatar
so it seems that the consensus is just go with the 2 ohm and be careful with the way it is set? and from what I've read this amp is a bit over rated and does not put out a true 900 watts
Old May 1, 2010 | 10:29 PM
JJDH's Avatar
10-4. Now keep in mind if you ever decide to go with 2 subs it would be better to get the 4 ohm sub, so if you add another later your amp will be able to run the subs properly.
