Best way to split RCA cables?
Old Feb 9, 2010 | 02:42 PM
Ryanmc86's Avatar
I have 2 amps a pdx400.1 and a kicker 750.1 and a pioneer avh p3100.
I have 2 sets of rca outputs in the back. What do i need to run the 400.1 on the front outputs and the 750.1 on the rear? I dont know how many splitters or which splitter i need.
Old Feb 9, 2010 | 05:05 PM
PorkCereal's Avatar
Run seperate rca's for each line. One output should be for sub output. If not run the rear to the sub amp and the front to the mids/highs amp. You dont need splitters unless the pdx is a 4 channel, then you can split for the inputs.
Old Feb 9, 2010 | 05:18 PM
Ryanmc86's Avatar
sorry yes the pdx is a 100.4 which splitters do i need? how many rca cables will i need?
Old Feb 9, 2010 | 05:21 PM
Ryanmc86's Avatar
this is what i think i need am i correct
http://www.sonicelectronix.com/item_...cker+SI43.html
http://www.sonicelectronix.com/item_...cker+SI23.html
and
http://www.sonicelectronix.com/item_...+-09ZIYF-.html
Old Feb 9, 2010 | 07:03 PM
Sundevil2188's Avatar
You do not need any splitters. Hook your PDX to the two outputs on your AVH. make sure the rear/sw preout is set to full range and not to sub. The PDX has an RCA out put on it that you would connect to your kicker.
Old Feb 9, 2010 | 07:21 PM
Ryanmc86's Avatar
Old Feb 10, 2010 | 09:02 AM
PorkCereal's Avatar
If he did that wouldn't he loose the ability to adjust his sub levels on his headunit? I think id rather have that ability then to save 5$ on splitters.
