confused about lanzar amp
Old Jan 28, 2010 | 10:08 PM
ridinmudddy's Avatar
so i just got a 1200 watt lanzar vibe amp. it says monoblock on the amp but its a 2 channel amp. i though all monoblocks were 1 channel amps?????? and im planning on running 3 subs so can i still hook all 3 subs up to the 2 channel amp? its not bridgeable and is 1 ohm stable. i am getting 3 single 4 ohm subs so i could wire that down to 1.33 ohms but i just dont know if using 3 subs on this amp will work
Old Jan 29, 2010 | 08:21 AM
PorkCereal's Avatar
1 channel = 1L and 1 R connection
If its 1 ohm stable and ur close to that, then you will see numbers for power close to that of what the amp rates at 1 ohm. As long as you dont go under 1ohm you shouldnt hurt the amp.
Old Jan 29, 2010 | 09:05 AM
so just use the channel on the very left and very right and itll be like a 1 channel? and yeah ill have it at 1.34 ohms so itll be good
Old Jan 29, 2010 | 11:04 AM
Sundevil2188's Avatar
http://www.lanzar.com/itempage.asp?MODEL=VIBE1801D
is it something like this?
My question is, why does the website list RMS output for the amp at 4 ohms, but max output for the amp at 2 and 1 ohms?
Old Jan 29, 2010 | 12:43 PM
PorkCereal's Avatar
1 x 1800 Watts Max @ 1.3 Ohms Bridged
Should be the spec hes looking for.
Old Jan 29, 2010 | 01:46 PM
its the older lanzar vibe 1200 watt "mono block" class d. someone gave it to me and it works i just need to know how i would run the wires from the 3 12 inch svc subs to the amp because the amp 2 channels as in 2 positive terminals and 2 negative terminals for the subs.
Old Jan 29, 2010 | 02:22 PM
ok its called a lanzar vibe 1200d its 1200 watts rms at 1 ohm 750 rms at 2 ohms im gonna have to get bigger speakers than i thought
