Another amp question (settings)
Old Jan 21, 2010 | 05:19 PM
alex06's Avatar
I am running a kenwood dx512 and DB571 they say the range is 52mhz-whatever
I am assuming if I use the preouts on my HU my high pass filter on the dx512 will no be used? So do I need to set the amp to HPF and turn the setting to like 60mhz or should I set it more like 80mhz?
Thanks just not sure how low the DB571's will take it.
Old Jan 25, 2010 | 07:53 AM
phattacorider's Avatar
The preouts on your headunit are all pass. Your radio will send out all frequencies played through it. Setting your door speakers to a high-pass system is dependent on how you like your sound. If you listen to your music loud, you may want to set it to high-pass. Play around with it at nominal volumes, you'll hear a difference. The higher you set your high-pass filter, the less bass you will hear out of your door speakers. Personally, I have my low-pass and high-pass on my headunit set to 80hz. That's just how I like it. Other people will tell you differently, others may tell you the same. Just play with it. Your Polks can take quite a beating!
