Connecting a SINGLE RCA OUTPUT
I have a JVC headunit that has a single "subwoofer" RCA output. How do I go about hooking it to an amplifier that has a left & right RCA input?
All of my previous headunits had RCA's with left and right outputs.
I have a Kenwood Mono Amplifier...
Did you actually look at the back of the headunit? Most headunits that say they have a single sub out means there is only one pair of RCA's...left and right and not 3 like you would need for a sub amp and 4 channel amp.
Amp Connection
My headunit has 2 front speaker RCA jacks, 2 rear speaker jacks, and 1 subwoofer jack. That would be 2 pairs and 1 individual sets of RCA jacks.
I am connecting a mono amplifier with one subwoofer to my headunit. My headunit has "integrated subwoofer controls" and I wanted to take advantage of that if possible by using the "Subwoofer RCA jack".
Is this possible by connecting the RCA jack to either the left or right only?
Could I get a "Y" RCA cable and connect the mono wire as the left and right on my amp?
Thanks.
I'll let you know when I connect it.. Hopefully it works!
You should be fine with just one subwoofer wire since it's all mono. I had an old Dual 7" DVD headunit and I got an RCA "Y" adaptor to ease my mind. I didn't notice any difference in subwoofer volume after I used the "Y" adaptor, but you can check for yourself. That adaptor is cheap everywhere.
