2 Amps which one will...
I have 2 amps
http://www.rockfordfosgate.com/produ...5&locale=en_US
And an older Depthcharge dc-4004 ( DC 4004 (Max power: 100 watts x 4; RMS power into 4 ohms: 50 watts x 2; RMS power into 2 ohms: 70 watts x 4; Bridged power into 4 ohms: 160 watts x 2; $199 SRP).
Which was given to me. Its a 4 channel bridgeable.
The punch 200.2 i currently have running my stock door speakers and im wanting to go with a set of componets. Will either one of these run them? Lets say a set of the PG Rsd 6.5. The main problem im seeing is the 4ohm load these pull and both amps only pull a 50w @ 4ohms. Not thinking thats going to be enough. And the DC Bridged 160w X2 will be too much power for those speakers.
Should i try and craigslist all of it and start over or can i make this work?
I also have some older Memphis Studio B 10's dvc X3 sitting in my office i need to unload.
Bridge the 4 channel to your components. Headroom is a good thing, the speakers can handle the power fine as long as you watch the sensitivity level on the amplifier. Those older amplifiers make cleaner power anyways.
The PG Rsd 6.5 Still the best bang for the buck with the amp im going to run. I think i found them the other day for like 40-60 a set. Almost ordered them but then saw the 4ohm req and held off.
Say ive got 100$ to spend, i still need to buy baffles, and door prep, plus prob new wiring.
