Mounting amps behind seat
Ok this is the frist F150 that Im mounting my amps behind the rear seat. My question is should I mount them on a amp board or can I just screw them to the parts of the back wall that stick out? Which would be better?
I have a standard cab and the peeps that did my install just mounted to the back wall. Thats all great until you want to change something then have holes. Id mount them to a board, gives you room to be flexable and to change later with minimum holes. Im about to redo mine.
some amps dont react well to being mounted to metal....could cause floor noise.....not all amps.....some....
usually ground loops. more than one path for ground. interference, signals, etc.. picked up through the ground..mount a metal amp to metal is like adding another ground
i mounted mine right to the cab wall. but there was the wall linig there from the factory so thats the only thing between the wall and the amp. a board would of taken up to much room for me. space was critical.
that is why i am rewiring my system grounds are good wire locations and routing not so much :o
Well I mounted my amps to a peice of wood just used some 1/2 plywood which made it easier to mount the amps
Now I have another problem the box i got out of a trade in at the dealership I work at came out of a chevy but fit prefect in my truck then I bought a Kenwood sub put it in the box and installed it in my truck and my sub sits right on the carpet. So now I have to figure out what Im going to do about that. Any suggestions?
