running power wire for amp`
Old Apr 19, 2001 | 07:56 PM
lewdog99's Avatar
Question running power wire for amp`
i would like to know if there is a way to run the power wire on the passenger side without haveing to run it under the pettles on the drivers side?
I would be greatful for any help.
thanks
Old Apr 20, 2001 | 10:11 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Talking
Hey lewdog,
I had a B&M electronic shift improver installed on my truck before I had my chip.
For that I had a small hole drilled in the firewall between the computer plug,and the fender. I just widened the hole a little,and threaded the power cable through there. Whatever you do,do not pull that 1&1/2" grommet out that is behind the battery!! I did,and it took an hour just to get the a/c vacuum line put back together.(no slack in it AT ALL )
You'll have to pull the battery out to get back there to drill,but it's a great place to run the cable. It lines right up with the door sill so you can run the cable back to the amp. Just make sure to use a grommet for the hole you drill,avoids shorting the amp out later. good luck on the install,,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's,,too noisy
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Clear front corners
Grillcraft grill insert
Speedglo gauges w/carbon fiber overlay,might paint it black
Stillen Quad light air dam,Sweet!!
Euro taillights
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,and Soundstream P203e amplifier//Single 10" sub
Viper alarm
On the waywheels,tires,Proglass shaker hood,new leather seat
the monochromatic boogie is done,cool!.
Come see my new pictures@ www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
I just wish it was lowered
Old Apr 20, 2001 | 09:43 PM
2000 F150 4x4's Avatar
Cool
How about pulling off the scuff plate and running it under there? There are holes in there too, you can pull the wire up thourgh a grommet. There are pics on this site of it if you search.
2000 F150 XLT 4x4 Short Bed. Amazon Green, 5.4L, SuperCab, ORP, Tow Package, Sliding Rear Window, Electronic Shift, Keyless Entry, LT265-70-17 Tires, Clarion Pro Audio, Herculiner Bedliner, Air Silencer Removed.
1994 SVT Mustang Cobra. #1032 of 6009. Black coupe with black leather int., 3.73 rear, Bassani Exhaust, Aluminum D/S, Bridgestone RE-71 255-45-ZR17
My Home Page
