Kenwood amp
Old May 19, 2009 | 09:40 PM
Justin_w32's Avatar
Kenwood amp
I have a Kenwood KAC-9103D mono amp max power is 1800W and 500x1 @ 4 ohm and 900x1 @ 2 & 1 ohm. I had 2 12" kicker comp cvr in a down fire in my old truck and it kept blowing the fuses on the amp, just when it sounded good (low bass) POP!!! another fuse. I belive i ran these in a series too not too sure what the diff is. Please consider im no pro, so i have no idea what effect some of the ***** on this amp actually have on the performance of my amp and subs. Im still not sure if these subs were performing to their full ability since i have heard other setups blow mine away.
Old May 19, 2009 | 09:59 PM
JJDH's Avatar
could be power wire size. also if u had that thing at 1 ohm or even 2 the power is flowing through that amp like a river, so pulling too much current, poor ground? sub distortion? might have to turn the gain down a bit
Old May 19, 2009 | 11:29 PM
Justin_w32's Avatar
thanx yeah i belive it was running at 2ohm/w a 6 ga. power. i may be getting 1 JL 12 would i need to upgrade my power wire to 4 ga.? and if i do would i need a 4 ga. ground as well?
Old May 20, 2009 | 06:05 AM
JJDH's Avatar
ground should be same size as power
Old May 20, 2009 | 01:50 PM
Sundevil2188's Avatar
6 guage wire is wayyyyy to thin for that amp. especially if your running at 2 ohms. I deffinitly recommend at least 4 gauge, and with that amp, youll need some crimp spades for because the terminals are pretty small, unless the newer ones got changed. also, i dont recommend running it at 1 ohm. Those things have a tendency to fry under that much load.
Old May 20, 2009 | 07:50 PM
Justin_w32's Avatar
Yeah it has been making a squealing noise, but as you would know i think my extended warranty from best buy is up already?
Old May 21, 2009 | 01:05 PM
How long ago did you buy it? Its either a 1 year manufacturs or a 4 year through us.
Old May 21, 2009 | 09:32 PM
Justin_w32's Avatar
I will have to dig through some boxes to find it weve moved since i bought it, but I know for a fact it hasnt been 4 yrs. ago.
Old May 22, 2009 | 01:07 PM
check your PM's...
